Brief Description: Aileron Bell Crank Assemblies and Rib #9
Cleco W21-10 x 2 Aileron Bell Crank Assembly and W21-02L & R Bell Crank Pivot Assembly to Wing Rib #9 to make W21-01L & R Wing Rib #9 Assembly. Fab W17-02, 03, 04, 05, 06, 07, 08, 09 Reinforcement Angle. DWG says use full size pattern as template, but height of uncut side of angle is not shown. Left full size, will see if the needs to be trimmed when the angles are installed.
