Worked on fitting T14-03 Vertical Stabilizer Tip and T11-01 Skin to T08-01 Vertical Stabilizer. Cut out rear edge of T14-03 fiberglass tip. To get proper alignment and insertion depth of the tip I made 4 clips to slide onto the edge of the tip, which will prevent inserting the tip too far into the Vertical Stabilizer.
