Brief Description: Fuel tank: Sending units and seal test
Laid out shop @F5 hanger at KAPA. Installed fuel sending units/access panels on left/right wing roots as per instructions. (Note: Did not use cork seals or rubber gaskets as per Van's builder asst recommendations). Sealed with pro-seal and balloon psi test with kit. Had several leaks. Repaired/resealed with proseal and retested. All good.
