Brief Description: Attached /tightened fuel lines & test ran engine..
...ttached /tightened fuel lines & test ran engine...Tightened fuel lines/fittings to fuel transfer valve. Used Fuellube on threads of fittings. Installed F640/F639 (goes on top) and labeled as such. Tightened lines to both fuel tanks. Tested L fuel tank after adding about 1 gal of fuel. Tightened one connection on fuel return line at fuselage fitting and no leaks. Labeled fuel lines and fuel caps 87 autofuel or 100LL/TCP.
