...Finalizing panel wiring. Placed plastic connector over d-sub for EIS MAP box. Made permanent connector for tach wire from SDS ECU to EIS. Labeled HOBBS fuse on bus tray under glove box. drilled 3/4" opening thru subpanel behind GTX 327 for antenna connection which should make antenna removal easier. Placed six D cells in ELT and labeled change date of Mar 2016. Unit tested okay.
