Paul disconnected the elevators after installing the trim motor and accompanying gear in the L elevator. It needs some extra weight for balance. The R elevator was about 4.5 oz. too heavy so some weight was removed from the front and rear of the outside weight by sawing on the bandsaw. This weight will be covered by the fiberglass cap. If additional adjustment is needed, then weight can be removed by drilling the inside weights.
