Brief Description: Installed battery bracket, engine mount prep...
The battery tray was bolted to the firewall using four AN3-5A bolts and 2 countersink 3/16 bolts. The top outside engine mounts are too wide causing the fuselage skin to bulge where it will butt against the engine cowling. The bottom mounts were trimmed by Eggenfellner so I removed the upper engine mount castle nuts, and washers to allow a forward shift in preparation of trimming 3/16" off outside out engine mounts.
