Brief Description: Drilled and placed ground bus on firewall...
...Drilled and placed ground bus on firewall...Drilled 5/16 hole in firewall using unibit and then filing. Placed ground bus inside fuselage and used bottom mounting bolt of the lower Moresco collant tank for 3/16 support.
