Brief Description: Drilled R fuel inlet line hole thru fuselage ...
...Drilled fuel inlet line thru fuselage from between wing and fuselage after aligning drill with mark extended from fuel inlet at tank. Hole was expanded to 3/16 from inside cabin with 12" drill bit and it aligned perfectly. Planned possibilities for 5/16" fuel return lines. Planned possibilities for ECM harness inside cabin and fuel pump assembly attachment to the cabin floor.
