Brief Description: Expanded fuel inlet holes in fuselage...
...Used unibit and air driven reamer to expand holes for fuel inlet lines for R/L fuel 3/8" line. Expanded hole diameter to nearly 1" for grommet fit. Drilled R brake line thru fuselage for AN833 fitting and secured with nut. Installed L brake assembly on wheel.
