Brief Description: Installed R wing light & completed wiring...
...Installed R wing light after reducing almost any excess plexi outside thw mounting brackets-with the belt sander. Then lens cover fit thru opening without interference from llight mounting bracket. Completed hot lead with connector and loop in wire. Can illuminate lights now by touching wire to battery terminal.
