Brief Description: More placeing of cowl for fitting...
...At Craig's suggestion I removed the alum. boxes that attach to the radiators as they interfere with placement of the cowls at the air inlet areas. I have already done some trimming of the inlets and it may require less if the alum. inlets are also trimmed which will be easier after the cowls are finalized. Everything always effects every other thing.
