Brief Description: Tightened brake lines and added fluid...
...Tightened all brake line fittings and used fuel lube on some in prep. for adding Mil-5606 brake fluid to syste. Zachary helped me remove top skin to give access to brake pedals and inlet fittings. Used David Cox's pump to add fluid from lower fittings which I craked about 1/2 turn. Discovered that all brake pedals ought to be pulled forward to preclude the piston to move and block the fluid from traveling beyond the master cylinders on each pedal. Mark & Michael got the Nieuport back on its gear as Zach helped me.
