Brief Description: Reinstalled flap motor & adjusted arms...
....Reinstalled flap motor and reattached flaps to drive links. had to shorten the links to get flaps fully up. It also became apparent that the safety wire modification is important as the jack screw can become unattached at the end of travel if the jam nut isn't properly tightened. Ran flaps up & down several times -oh the joy! Once moving the flaps draw about 2.5 amps and if you continue to hold the switch after they are retracted or extended the amps increase above 3.0.
