...GTX-327 antenna installed. Drilled hole thru floor andmounted with mounting nut inside cockpit Also used the template to drill for SL-40 Comm radio antenna. The antenna cables I had one end pre-wired by SteinAir and asked for them to be 4 ' length. I couldn't reach my desired location of under the gear weldments-blasted Scottish heritage! Bob Pickens soldered the tips in and I used the co-ax squeezer for the rest. Rqadio Shack makes a cutter to prepare the cable. Added GRD to dimmer. Tested SL-40 by running batt. power to it.
