Brief Description: Wired LED dimmer to light switch...
...Wired LED dimmer to light switch but the elev. trim LED is dimmed inspite of the position of the dimmer. Attached GTX-327 wires to Nylon sticky tie on F/W. Borrowed a RX cable wire stripper from Jim Bower to prepare radio and transponedr wires for crimping connectors on ends. Soldered Pilot Mic jack BRN/WHT to Ring BLK to sleeve BLU to ring BLK to SLV BLU/WHT to tip BLU/YEL PHO ring BLU/BLK PHO tip
