Brief Description: More labels, wires to switches & circuit breakers.
....Added Red on white EMER PWR label for Emergency Power switch and Red on white Engine Direct label for "Hail Mary" switch which bypasses ECU & Main Fuel Pump CB with direct power from ESS Bus when switch is activated. MAP sensor wires rerouted thru grommet on subpanel for ease in panel removal. Had to remove wires from Dsub and reattach after rerouting. Fuel Pump panel annunciator lights grounded to center panel GRD Bus. Aux Fuel panel annunciater light attached over Aux Fuel pump power wire for operation. #16 Jumper wire run from ESS Bus to ALT Field CB since that CB is not attached to the ESS Bus Bar.
