RON'S WEB SITE
Date: 8-4-2009
Number of Hours: 3.50
Brief Description: GRD wire for panel to firewall GRD, wigwag...
....Made #10 GRD wire to run from the GRD Bus on the glove box to the firewall GRD-used fast on tabs for each end. Labeled VA-1A wires for easier installation later. Greg Smith used an ammeter to figure out the wiring so I could label the terminals of the wigwag switch. Made labels 1-6 for the switch and installed. Began matching the wires to the plan. Labeled theMain tray ATC busses. Rerouted MAP by pulling the Dsub pins and reinstalling them. Current plan: Main Bus-HTR, Flaps, LDG lt, Taxi lt,VA1A, Nav, Strobe, AOA ESS Bus: Fuel pumps, ECU, ALT FLD, EFIS,EIS, MT Main Bus feeding Avionics Bus thru AV switch on panel: ICOM, GTX327, SL40, TRIM, Panel lts, Auto pilot
