Brief Description: Drilling mains for cotterpins...
...Drilling mains axles for cotterpins...Marked R axle with punch with wheel bearing snugged up. Drilling is difficult with wheel installed but was able to drill thru with a 12" #40 drill then enlarge with a #30 on top. Sharp drill bits are a must! Drilled thru after removing wheel with #40 from the other side using mounting nut installed as drill guide. Used Rick Galati's jack to remove wheel. More sanding on windscreen
