Brief Description: Taking measurements for empty c.g.
...Taking measurements for empty c.g....It takes more to level the aircraft fore and aft than can be done by letting air out of the nosegear. It takes at least 2.25 inches under the main gear. Side by side can be done by varying main tire pressure. Used 60" forward of leading edge of the wing by hanging a plumbob off each side and using chaulk line. the NG is 29.25 aft of datum, and the mains are 89.1 aft of datum. Added more blue filler after sanding on windscreen.
