Brief Description: Filing to get full freedom of all flight controls.
...Filing to get full freedom of all flight controls...Removed empennage fairing and rounded inboard area of R elevator where it contacted HS spar slightly. Filed elev. push rod channel on upper L side where it made contact with the doghouse area under the flap motor housing. Filed additional area off seat supports where contact was made by addition of autopilot control linkage on pilot side of aircraft. All control movement is unimpeded now.
