Brief Description: Setting timing schedule on SDS system...
...Setting timing schedule on SDS system...Tied and chocked aircraft outside after using shop vac to clear stones from area ahead of prop. Set timing schedule as rec. by racetech using timing light and adjusting Magnet seen position from 80 to 83 degrees with timing at 10 degress BTDC.
