RON'S WEB SITE
Date:  7-8-2010
Brief Description:  Bled brake system and added fluid...
...Bled brake system and added fluid...Attached bleed pump on each brake fitting and pumped fluid up to res. but could not dispel all the air. Attached a vacuum pump from Harbor Freight and was able to draw air out thru the bleeder valve. Used a NPT connector in the firewall res. with a tube attached in the fill bottle for the MIL 5606 brake fluid. Worked like a charm. All brake pedals are firm and few air bubbles in lines over brake pedal assembly.
