Brief Description: Adding washers behind spacers for clearance...
...Adding washers behind spacers for clearance to resolve the 2 bottom bolts that hold the gearbox to the engine mounting plate and were touching the new tortion flywheel. Adding a 970-06 washer behind each factory installed spacer did the trick. Also modified engine plate to allow more clearance for coolant hose underneath the pilot side radiator.
