...Routing/shortening & securing SDS wires. Drilled hole in lower portion of Batt. tray to secure O2 sensor connector and secured sensor wires to engine mount. Put split loom over WT (water temp) sensor wire which is secured to leg of engine mount. Shortened coil GRD wire and attached to engine GRD bolt nearer coil.
