...Setting fuel pressure auto-changeover. The fuel pressure before start was 35psi so we adjusted the adjusting screw to operate at 25psi. It works like a charm and when I pull the main fuel pump cb with the engine running, it switches to the aux pump without skipping a beat. Cut thru subpanel for the SDS monitor to extend forward to panel and placed split border over hole to protect wires. Added and secured more split loom over engine SDS wires.
