Brief Description: Bending L aft skirt for better fit...
...Bending L aft skirt for better fit......Removed and replaced side skirt and aft skirt several times to roll over knee in hopes of better fit. Sanded and filed aft-most top corner of rear plexiglass (as it has a natural curl upward) in hopes that it might lay more level over the rivet line. Trimmed part of bottom off and made outline of final shape for trimming later. Began shaping R skirt as well. Drilled center post for 1/4" bolt using 12" drill
