Brief Description: Installed handle on PAX side of roll bar...
...Installed handle on PAX side of roll bar...Aircraft extra handles are convenient to assist getting in and out of the RV-6A. Drilled inside 8" from centerline with enough clearance so that installed handle will not hit slidier when it moves forward. Made template for handle to insure proper distance apart when installed. Drilled with 30; 3/16; 1/4; 5/64 and then P so handles slide inside roll bar. Secured with AN3-3As.
