Brief Description: Refabricated L tank internal fuel return line...
...Refabricated L tank internal fuel return line. I had made the first line with too many bends making it difficult to insert so I made another coming from the AN837 elbow which extends inside the tank at a 45 degree angle and then bending 135 degrees to enter the hole in the second rib and parallel the tank bottom. I flared, bent and cut a tube for the R tank, and drilled the inner hole near the bottom of the second tank rib and expanded it to 1/4". I need a 5/16 drill bit 12" long to complete the task.
