Brief Description: Fabricated R fuel return line...
Fabricated R fuel return line. Cut hole in R tank for return line. Flared and bent tubing with less bend than first attempt on L tank line. Drilled hole in bottom of second rib to distribute return fuel in outer bay of tank. Temp. installed in tank. Will need to be prosealed under return line washer for final installation.
