Bobs Ten
RV-10
ER Fuel Tanks
1-30-2014
Install Left ER Tank Access Panel
1142 - 1348
Layout and drill access panel hinge using #40 drill.
Fabricate 2 spacers for panel hinge so hinge will sit flush with wingtip from 063 sheet.
Match drill panel and spacers using #40 drill, cleco as drilled.
Layout panel on wingtip.
Cut panel opening in wingtip using permagrit tools.
File and sand wingtip opening to final size.
Match drill wingtip for panel hinge using #40 drill, cleco as drilled.
Using english wheel, finish form the panel doubler.
Drill top left and right pilot holes in doubler and wingtip.
Dril #40 hole in center of doubler. Install cleco in this hole to use as handle for positioning doubler.
Drill wingtip and doubler mount holes using #40 drill, cleco as drilled.
Install panel, hinge, and spacers using clecos.
Verify fit of panel and doubler.
Adjust all edges and smooth with 180 s/p.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
