Had to modify fabricated brakets to allow main fuel supply to pre filter connection at a later time. This involved shortening the brackets at the fuel line pass through. Doing this allows the brake line supports and fuel return flex line supports to be installed at this time while allowing access to connect the supply line to the pre filter once the wings are mounted.
