Bobs Ten
RV-10
Empennage Attach
1-9-2013
11-6.4>6, -7.1>3
Rivet Empennage Attach Elevator Pushrod, Trim Serv
1154 - 1321
Verify pushrod tube internal primer was completely dry.
Install threaded end to pushrod tube, cleco into position.
Rivet threaded ends using MSP-42 rivets pulled with p-puller, 12x.
Install pushrod into tailcone, bolt to elevator horns and bellcrank.
Check for maximum elevator travel. Full Up = 29.5 degrees. Full Down = 26 degrees.
Secure elevator in trail position.
Fabricate bellcrank angle template from 3/16" MDF.
Adjust pushrod end bearings to comply with template. Required lengthening by 1/2 turn on each bearing.
Tighten Jam Nuts.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
