Bobs Ten
RV-10
Empennage Attach
1-4-2013
11-6.4.5.6.7, 11-7
Empennage Attach Trim Servo Mount
1218 - 1330
Cleco trim cable anchor brackets to mount.
Verify brackets are parallel to cutout in mount.
Match drill brackets using #30 drill, cleco every hole.
Remove clecos from servo spacer corners.
Final drill corner holes using #28 drill.
Machine c-sink holes in servo spacer, 8x.
Final drill applicable holes in mount using #40 drill.
Machine c-sink #40 holes in top of mount, 8x.
Final drill mount closeout tabs using #30 drill.
Debur all holes.
Clean all parts for priming.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
