Bobs Ten
Date:  4-29-2020
Number of Hours:  1.30
Brief Description:  Bleed Brakes
1736 - 1854
All fittings checked.
Bleed brakes as previously detailed.
While I was bleeding the brakes, I decided to drill the oil sump Tee plug for safety wire. It is not likely that the plug would vibrate loose but the safety wire will guarantee it won't.
I will safety wire it tomorrow. I need to figure a way to safety wire the oil quick drain, and will do both at once.
