Bobs Ten
RV-10
Cowling
7-15-2017
Install Cowling
1700 - 1918
Fabricate two double Skybolt brackets from .040 aluminum sheet.
Clamp double bracket to firewall flange in previously located position.
Match drill bracket to firewall flange, cleco as drilled.
Layout bracket center lines and rivet lines on skybolt brackets.
Position next bracket to maintain a nominal 1/4" reveal and 3 1/2" center to center distance, clamp in place using cleco clamps.
Match drill b racket to firewall flang, cleco as drilled.
Repeat process until top center of cowl was reached.
Next, the other double bracket will be placed and the process repeated.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
