Today was spent designing and fabricating a new rack for the ECUs. After a discussion with Robert at Flyefii, it was noted that the SD card for the System 32 ECUs needed to readily accessible for programming and diagnostics. This necessitated moving the planned location as the original location would be inaccessible with the instruments installed. For this reason, I chose another location, behind the passenger side efis and on the underside of the rack. This will allow easy, tool free access to the SD cards.
I am going to stack the ECUs on the bottom of the rack. They will be out of the way and out of sight but easily accessed.
Standard techniques were used to fabricate the rack shelf. I used a short section of aluminum hinge along the sub panel flange. This allows the rack to be pivoted down to access the top side. I trimmed the corner of the rack shelf to provide clearance for the passenger side vent SCAT.
The rack shelf will be secured at the front edge using #8 screws.
