Bobs Ten
RV-10
Doors
1-8-2016
45-12.1>4, 45-13
Door Latch Mechanism
1518 - 1900
Working between three sets of intructions.
Using vans plans, fitted door pin blocks using bench sander and dremel.
Match drilled doors using #12 drill.
Match drilled door wall using 7/16" unibit.
Removed vans door pin blocks.
Enlarged 7/16" holes to 11/16" per planearound plans.
Using bench sander and dremel, fitted planearound door pin blocks.
Clamped door pin blocks in place and match drilled them to the previously drilled #12 holes in the door.
Remove pin blocks.
Locate and drill clearance holes for door racks using 1/2" unibit.
Assemble door latch mechanism for right side door per vans and aerosport instructions.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
