Bobs Ten
RV-10
Cabin Top
1-10-2015
43-8.1>4
Install Cabin Top Front Support
1654 - 1842
Locate and mark centerline of cabin top. Measurements were taken from the door channels and a line was strung from the tailcone skin centerline.
Final drill front support upper bracket using #12 drill, 4x.
Position and clamp the front support.
Using a drill cup and bushing, match drill cabin top to front support using #12 drill.
Install AN3 bolt.
Final drill remaining holes using drill cup and bushing with #12 drill, install AN3 bolts as drilled.
Position front support lower bracket using 032 shim.
Match drill front support lower bracket to forward upper fuselage rib.
Install AN3 bolt, drill remaining hole usig #12 drill.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
