Bobs Ten
RV-10
Empennage Fairings
1-7-2015
Install Rudder Tip Fairing
1800 - 1924
Trim rudder tip fairing flange to fit rudder.
Remove aft section of flange to provide clearance.
Sand and smooth all edges using permagrit tools.
Install fairing in rudder.
Match drill fairing from front to back using #30 drill, cleco as drilled.
Remove clecos and fairing.
Debur holes.
During sanding, the fairing began to crack along its seam. I decided to layup one layer of 9 oz cloth over the seam.
Cut cloth, wet out cloth, layup cloth over inside seam.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
