Bobs Ten
Date:  9-15-2020
Number of Hours:  4.00
Brief Description:  Miscellaneous Tasks
1100 - 1500
Remove plastic film and tape from windows.
Install front interior panels. Then I realized that I needed to install the map pockets before the panels so I had to remove the panels.
Received version 1 of the cabin top handles. Check for placement.
Install plastic plugs in step bolt holes. Unfortunately, one was a different size so I will need to order new ones.
Install access panels beneath horizontal stab. I decided to use mcmaster edge trim with a 1/4" bulb as a seal. Panel was installed with #6 Torx screws.
Spent remainder of time configuring the G3X...
