Today I installed the center console side panels. Some minor adjustments were required to provide clearance on wire bundles. Edges that were in proximity to the wire bundles were protected using a piece of split rubber tubing.
Next, the center console was installed using AlloySteel Torx screws. Minor adjustments were made to improve fit.
The fuel selector handle was also installed.
I clecoed the upper baggage area bulkhead cover in place.
