Bobs Ten
RV-10
Install Mounts for Vent Tubing
1530 - 1706
I fabricated a U shaped mount to support the fresh air vent ducting in the tailcone.
I used 1" square 6061 tubing to fabricate the mounts. One side of the tubing was removed using the bandsaw. Holes were drilled for blind rivets.
The mount was deburred, shaped and smoothed.
Next, the mount s located and clamped into position. The bulkhead was match drilled.
All holes were deburred.
A large tie wrap mount was installed on the mount using adhesive tape.
The mount was clecoed in place and riveted using aluminum rivets.
The process was repeated for the opposite side.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
