I finished the Bus Manager mount and attached it to the throttle quadrant using AN hardware. I needed to use two nylon spacers to allow clearance for the throttle/prop cable mounts.
The Bus Manager sits in the mount, surrounded on each side by aluminum angle. I decided to trim the aft end of the mount to provide easier access to bus wiring. The Bus Manager will be secured in place with two long tie wraps. The tie wraps will prevent the Bus Manager from separating from the mount and provide easy removal, if necessary.
The Position of the Bus Manage allows easy access to the fuel pressure sensor adjustment and the control harness plug.
