Bobs Ten
Date:  12-16-2017
Number of Hours:  1.50
Brief Description:  Install Oil Door
1200 - 1330
Trim and smoothe edges and surfaces of oil door.
Trim opening in cowl to facilitate hinge clearance.
Locate hinge on door with double sided tape, verify fit and operation.
Match drill hinge and door using #40 drill, cleco as drilled.
Remove clecos, debur holes.
Fabricate cowl side hinge spacer from .125 6061 aluminum.
Attach space to hinge with spray adhesive.
Center door in cowl opening, tape in place with packing tape.
Due to the curvature of the cowl, the hinge will not lay flat. The solution was to mix epoxy/flox/cabo and create a parallel surface for the hinge. Standard techniques were used to prevent bonding of the hinge to the cowl.
