Bobs Ten
Date:  4-22-2017
Number of Hours:  3.00
Brief Description:  Install Wiring, SCAT
1206 - 1506
Pulled guide wires up through the windscreen bow conduits.
Opened hole to pass wires through the cabin top brace.
Installed forward cabin heat scat tubing to firewall valve and footwell Tee.
Machined 8 nylon spacers for cooling fan mounts using Smithy.
Installed two avionics cooling fans in forward fuselage top. The fans are Noctua NF--F12 IndustrialPPC-200. Specs are 2000 rpm, 122 m^3/hr, 3.94 mm H2O, 29.7 dB/A, 0.1 A. Very quiet and move a lot of air.
