Bobs Ten
RV-10
Install Static Source Plumbing
1300 - 1336 1436 - 1712
Remove elevator pushrod.
Secure pushrod jam nuts with loctite and tighten, 4x.
Remove battery tray.
Vacuum and clean dust from tailcone area.
Install Static source plumbing using Safe Air 1 fittings.
Insert Kyle into fuselage! This would have taken me five times longer if I had to get in the tailcone. Thanks Kyle!
Install 90 degree pipe thread to push fitting in each static port.
Fabricate mounting bracket for static source Tee from 6061 angle.
Match drill bracket to bulkhead.
Debur holes.
Rivet bracket using LP4-3 rivets.
Install Tee fitting on bracket.
Fabricate two static lines to run from Tee to static ports.
Install lines.
Locate and mount Adel clamps to support lines.
Determine location of main static line.
Locate and install Adel clamps and snap bushings to support line.
Remove Kyle from fuselage!
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
