Bobs Ten
RV-10
45-16.2>4
Fabricate Gas Strut Jig
1800 - 1936
Fabricate bushings per plans, modified for iflyrv10.com strut brackets. using Smithy Lathe, 4x.
Separate grind, sand, debur, and smooth all edges of C-1013 strut attach brackets using bandsaw, file bench sander and s/b wheel, 4x.
Fabricate strut jig using 1/4" masonite per plans.
Assemble strut jig using temporary hardware and washers to center jig between brackets.
Temporarily install in fuselage.
Verify fit of C-1013 brackets on door surface, adjust as necessary to provide clearance for the window opening return.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
