Brief Description: Prepare Door for Low Profile Handle
1524 - 1718
Prepare door for Aerosport Low Profile Handle.
This process was detailed for the left door.
Adjust strike plate to fit.
Drill specified holes, sand to finished diameter.
Drill rack clearance holes per vans instructions.
The were a couple of areas in the handle pocket that had minor voids from bonding. A mixture of epoxy/flox/cabo was injected into these voids using a syringe. Skins were compressed and released in these areas to help distribute epoxy. Once hardened, holes will be sanded to final diameters.
