Position and fit gas strut attach bracket to cabin top with seal in place.
The fit against the cabin top fiberglas was, as expected, poor. Using permagrit tools, surfaces were adjusted for best fit. As I was not satisfied with the bearing surface, I mixed some epoxy/flox/cabo, taped the bracket, applied the epoxy to the bracket and installed the bracket. Hopefully, this method will yield a flat surface for the bracket to attach to.
The Aerosport handles came in the mail today.
Begin fabricating the door handle assemblies.
Debur and fit the handle lever to the slide per plans.
Debur and file the groove in the handle to fit the lever.
Final drill lever and handle for #8 screw per plans.
Locate and match drill nut plate in handles.
Debur and countersink nut plate mount holes in handle.
Rivet nut plates to inside of handle per plans using hand rivet puller.
